wtt super clean and modded 96 svt cobra for ls1
Well a few months back i sold my 98 camaro z28 and i just miss the ls1 scene. This car is in super good shape for having just turn 96k original miles but it looks like new. I am located in bakersfield ca 93313, and you can reach me on my cell at (661)348-9895 if interested. This car is not the fastest but it handles great because of the nice suspension, this car is pretty much setup for auto x racing. I only daily drove the car but did take it to the 1/4 mile track once and ran a respectable 13.5 at 105 on street tires. On slicks and if you upgrade to a 4.56 gear ratio the car should run 12's!
This is a great car in awesome shape and running condition. Black on black with 5% limo all the way around. The car was recently smogged and tagged. The car has 96k original miles but the engine has only 60k, replaced by ford at 35k. Only fully synthetic oil and fluids used and changed every 3k miles religiously. The car has brand new redone seats, and carpet! New cobra floor mats and bullit pedals along with a new sony xplod deck with new speakers. Performance wise the car has every bolt on made except for headers. The suspension of the car is where the big bucks were spent on this vehicle $5k (Tubular K-MEMBER, COIL OVERS, CC PLATES, TOWER BRACE, SUBFRAME CONNECTORS, A-ARMS, BILSTEINS, UPPER & LOWER CONTROL ARMS, TIE ROD, BUMP STEER KIT ECT.....). This car is extremely well taken cared of and i just spent $$$$$ on doing a tune up.
NEW
Magnaflow tru x pipe w/cats
Bosch O2's f&r
Oem plug wires
Autolite plugs
Drilled and Slotted rotors f&r
Brake pads
Autolite battery
Screaming demon coil packs
UPR clutch cable and triple quadrant adjustable kit
New gatorback belt
10w30 mobil synthetic 7qts
Oil filter
New radiator w/160 thermostat
Fuel filter
Oil separator
Tps sensor
Oem 04 chrome svt wheels w/ new falken azenis 275/40/17
New headlights
The rest
TKO tremec 600 transmission
Aluminum flywheel
Aluminum driveshaft
3.73 gears
Stage 3 clutch
Pro 5.0 shifter
Steeda pulleys
Borla XR1 catback
C&M intake system w/80mm air meter
30lbs injectors
bbk fuel pump
cobra chrome inserts
fr500 steering wheel
rear strut brace
NEW
Bosch O2's f&r
Oem plug wires
Autolite plugs
Brake pads
Autolite battery
New gatorback belt
Oil filter
Fuel filter
Oil separator
Tps sensor
New headlights
The rest
Aluminum flywheel
Aluminum driveshaft
3.73 gears
Stage 3 clutch
Pro 5.0 shifter
Steeda pulleys
Borla XR1 catback
30lbs injectors
bbk fuel pump
rear strut brace
at the time selling my ls1 made financial sense i needed to get rid of some debt and selling my car made the most sense so i did, the cobra i picked up for a good deal!
