Dry Kit
Dry Kit
I purchased a dry kit for my car recently and i was wondering if anyone had an idea what i would be running on a 75, 100, and 125 shot on a 02 Z28 with 3:23s, drag radial, and slp lid? About what would my gains be and what should i watch out for and is there anything i should change before i start spraying? Thanks!
You could probably drop over a second off your current ET with a 100 shot. Just make sure you put some NGK TR6 plugs in (or Autolite 103) and gap them .035. It would also be a REALLY good idea to hook up HPTuners or at least a wideband to the car to see what the A/F ratio is (get an O2 bung welded into the exhaust) and make sure you're not getting any knock. Stock fuel pump *should* be fine, stock injectors *should* be fine but it should be checked just to make sure.
