lt1 help
lt1 help
was wondering if any of you guys might be able to help me pin point my problem
ok i swapped what i found out is a 94 LT1 (thought it was a 95)into my 84 corvette. got all the wiring hooked up, gettin 5 volt references at all the places im supposed to be gettin it but all it doesnt is crank but no start. im not getting any spark.VATS has been deleted
could it be:
bad opti
opti module
igniton control module
electronic spark control module
i just want to knwo what i have to buy to get it running. wish i had the money to do the whole swap to get away from opti but maybe some other day.
this is all it does
could it be:
bad opti
opti module
this is all it does
I just put a 95 LT1 into my 94 Trans Am and having the exact same issue. It is with a brand new coil, optispark, and wires. This probably isn't much help, but at least you are not alone. If I figure out what it is, I will post more helpful information.
Lance
Lance
