Drag Racing Tech
Ozite question
Old 05-21-2009, 03:53 AM
o2bird's Avatar
Default Ozite question
What are you doing for wiring that needs to go under the carpet. Im dynamating the whole car and want to use ozite or similar to offset the weight. Im going to have full stereo with a couple subwoofers and amps along with the control unit for the DVD player. Then i have wiring for 2 bottle heaters and pressure gauge plus a -6 nitrous line and a couple other things, plus the factory wiring. I have no problem putting the time in to make it right and follow all the contours but i really dont want to see lines of wiring going down each side. Just wondering what others are doing when gluing the carpet down. Thanks
Old 05-21-2009, 04:56 PM
fenton06's Avatar
run the wires under the console and then to the plastics?
Old 05-21-2009, 09:07 PM
TJ
TJ's Avatar
still has to make it under the carpet.
go with the cheapest molded carpet you can find, IMO.
i have some ACC stuff in my 3rd gen. its not super heavy. hardly any jute padding. lot less than factory.
