afr 59cc ms4 guys come in!!!!!
Old 05-21-2009, 09:58 PM
johnster's Avatar
Default afr 59cc ms4 guys come in!!!!!
what pushrods r you guys runing? 7.35 or stayn with the 7.4 o ya with a .40 head gasket thanks john
Old 05-21-2009, 10:05 PM
5.3LJimmy's Avatar
I'm running 7.35's with my setup, but I don't have AFR heads. Heads are milled to 58cc with an 0.040 gasket.
Old 05-21-2009, 10:13 PM
Restricted User
willyfastz's Avatar
The only real way to know and the only way you should do it, is to measure. Your lifters and valve train don't understand internet math. It's really easy to measure and companies like Manton can make any lenght pushrod you need.
Old 05-22-2009, 07:18 AM
quick346's Avatar
7.4 with 59cc afr's and a .040 gasket on xer lobe's. not sure what the base circle is on a ms4. but with xer lobes the 7.4's are good to go
Old 05-22-2009, 07:55 AM
Restricted User
willyfastz's Avatar
Is that "good to go" on every car with those mods? What preload will he have if he just drops 7.4's in?
