adapters from EV1 to EV6?
Old 05-21-2009, 10:27 PM
litch2004's Avatar
Default adapters from EV1 to EV6?
Is there a company that sells a EV1 style plug to a EV6 style plug adapter?
got a good deal on a set of factory 39lb injectors off of my buddies cobra
Old 05-21-2009, 10:51 PM
litch2004's Avatar
Nevermind i actually found a set for fairly cheap. Now is there an actual benefit to having the EV6 style over the conventional EV1?
The injectors were just rescreened and cleaned by the Ford dealership and i am getting them for $100. The injectors only have 100 miles on them.
Old 05-21-2009, 11:22 PM
the_merv's Avatar
Katech is one of the ones that sells them..
I used LS2 Injectors with my build. I needed the EVI 6 Conectors and managed to get some un-assembled ones to wire onto my Harness.
Old 05-21-2009, 11:24 PM
litch2004's Avatar
is there an advantage to using the EV6 style over the factory EV1 style? And will they work on the LT1 fuel rail and manifold?
Old 05-21-2009, 11:34 PM
the_merv's Avatar
Depends on the Injector. From what I hear the newer style Truck Injectors are pretty stout, they are EVI 6 if you wanted to run them..
Quick Reply: adapters from EV1 to EV6?
