can you use ls2 6.0 rods/pistons in lq4?
Old 05-22-2009, 09:26 PM
retro1977's Avatar
Default can you use ls2 6.0 rods/pistons in lq4?
Can i use ls2 6.0 rods and pistons in a 04 lq4 without and issue's? thinkinf using the flattops along with some 243 to bump the comp/ thanks
Old 05-22-2009, 10:28 PM
Soul TKR's Avatar
considering an LQ4 is a 6.0, and an LQ9 has flat top pistons anyways... I'd think so...
Old 05-22-2009, 10:31 PM
retro1977's Avatar
Thankyou, did a search and didnt find what I was looking for also are all lq4 rods pressed fir or are some years full foating, seen both answers
Old 05-25-2009, 08:43 AM
jmm98LS1's Avatar
I think all the '05 and later 6.0's used full floating pins, I know that's what's in the LS2 and LQ9's (which came out in '05).
Old 05-25-2009, 03:38 PM
1FastBrick's Avatar
The LQ4 are a press pin rod but the 05 LQ9 and LS2 engine's both use the same rod and piston. You will not find an Lq9 Piston listed for a stock rebuild application Because it is the same as an LS2 piston. It's been done on the truck side of the forum. You must use the correct piston with the correct rod and pin.
The following users liked this post:
Homer_Simpson (04-16-2023)
Old 05-25-2009, 08:51 PM
retro1977's Avatar
I have a 03 lq4 and found a set of ls2 pistons and rods, would I need to re balance ? or anything major
Old 05-26-2009, 01:06 AM
1FastBrick's Avatar
You would have to weigh one of each set up. Unfortuniatly I don't have any weights for either set's of parts. I have LQ9 pistons but I got rid of the LQ4 pistons I had. I also don't have The New floating pin rods yet. I have been meaning to call the guy and get them but I have not had any extra cash.
Quick Reply: can you use ls2 6.0 rods/pistons in lq4?
