would an improperly installed 2/4 servo cause overdrive not to work but 2nd to be unaffected? i bought a used transmission, installed a servo, and there is no 4th gear.
I would remove the servo and check the telflon ring on the outer servo in the cap. Also you do have the rubber oring on the second part of the corvette servo dont you?
