44psi on stock lines = 44psi on braided?
It should right?
I have my A1000 regulator set at 44.2 psi on a -8 feed/-6 return and the car is reallly rich. Im not tuned so i figured that was the main reason but I was loading the car on a trailer recently and the tank was low on gas, getting up on the trailer the pressure gauge dipped to 33psi and held strong, wideband jumped from the 10.2 area its been at, all the way up into the 11.8-12.3 area.
So my question, although I'm untuned, is setting the stock pressure for the original LT1 too much?
