#1 cyl injector is only one pulsing
03 5.3, custom harness, original mapped ECM, no smog, 4L60E trans in a 40 chevy truck. 56 lbs fuel pressure in rails, #1 cyl is only one firing, replaced crank positioning sensor, I am seeing that the only injector that is pulsing is #1, if I spray starting fluid in the throttle body it will run till all fluid is burned up.....so.....why are the other injectors not pulsing, the internet is saying that the computer is only recognizing the #1 cyl position......but thats not the issue......if that were the case it would not run at all. I just replaced the crank positioning sensor.....and no change
