how do you use the mity vac on clutches? NEED HELP ASAP
how do you use the mity vac on clutches? NEED HELP ASAP i just sucked my line dry trying to figure this out. do u have to crack my bleeder screw and place the proper attachment to the bleeder screw
no... look for the thread man...ill try to find it...but keep the bleeder closed at all times put the little hose to the can then the foot long hose with a cone attachment that will fit in the hose. Now take the cap off the res. and put the hose in the hole in the bottom of the cup and opump it up to 20 and watch the bubbles come up the hose while pumping the clutch.
that link didnt work but thats the way i did it and thought i did it wrong. haha there were huge bubbles coming out and i thought i sucked all the fluid out of the line. well i sucked it all out of the rez. i must have to pour fluid in before it take the bleeder hose out so it stays full i suppose
