Digital Odometer & Tripodometer Not Working
Old 05-28-2009, 12:22 PM
METALBEAST's Avatar
Default Digital Odometer & Tripodometer Not Working
Finally got my 97 Z28 running correctly. Last problem I need to sort out is the odometer & trip odometer. When you start the car up, all the other gauges seem to work correctly with the exception of these two. They are blank & not lit up. I don't seem to have any ground wires loose so I am perplexted as to what this could be. Any thoughts?
Old 05-28-2009, 12:44 PM
NonGoggleGuy's Avatar
Check the bulb behind that LCD window.
Old 05-09-2010, 08:22 PM
Tony West's Avatar
Could this be the same for a 98? Mine went out today but if I look close enough I can see the mileage.
Quick Reply: Digital Odometer & Tripodometer Not Working
