98 v6 to ls1 swap, pump question
i've yet to fire my car up, but quick rundown, its a 98 v6 car with an ls1 swapped in and a billet fuel rail with regulator (so I could use stock lines) set at 40psi. Car has the stock v6 pump still in it. Does anyone actually know if the v6 pump can keep up? I've tried searching but no luck. If the v6 pump basically flows the same as an ls1 pump i'm sure it will be fine, but in my head it seems like id need to turn the pressure up closer to 50psi to keep up the volume.
any help greatly appreciated guys!
