Cant Quick Shift........ i tried searching
Stock Hydros
Stock Clutch
No Drill mod
A few months ago, outta the blue I started having trouble getting into gear (any gear). I checked fluids and found it was low so I filled. Every since then, not only does it leak but, whenever I try to shift at high RPMs (WOT) all gears, it wont go into gear for about a half to a whole second (which really sux for racing).
For instance, I take off, redline, attempt to shift, unable to, a sec later it goes in, same with all gears.
I was told it was my SLAVE. I have a monster clutch at home that came with a slave which will be going in soon but I just want to make sure its the problem while everything is out.
Stock Clutch
No Drill mod
Stock Hydros
Stock Clutch
No Drill mod
Stock Clutch
No Drill mod
