Manual Torque Convertor Lock Up Switch
Does anyone have a write up or know where I can get a write up on doing the manual switch mod to my torque convertor?
Has anyone here done the mod? If so what did you think of it?
Thanks ahead, Dave
Thanks ahead, Dave
Originally Posted by Hugger SS
LMAO
tap in to pin # 42 I believe...tan with a black stripe in the red connector. Run one end to an on/off switch and then to a ground
Originally Posted by Farmer2
Thanks for the help bud, I'll give that a shot after I see if your Pin 42 is the pin out.
Just did a check for ya...
Pin 42 / Red connector
TAN/BLK wire
TCC Solenoid Valve Control
Something is making me think that the 98's were different. I know there was some mod I remember reading about a while back that had a different wire on the 98's than the 99-02's. Mabey that was the tach wire I'm thinking of?
