DRL module bad?
DRL module bad?
as we all know... the front turn signals on our LT1 cars are lemons. but i have a different scenario. the front right turn signal does not come on or flash. the park lights work and the right rear turn signal comes on. it acts as if a bulb is out at the right front. i have no current at the socket for the turn signal and the ground wire from the socket is good and has continuity. i looked at a wiring diagram and the only part that could be the problem is the drl (daytime running light) module. has anyone else had to do this? a new one is $400 from the dealership. just figured i should ask the fellas before putting down that kind of money. thanks
