10 psi stock long block fuel pump
I'm doing a twin t3/t4 build on a 02 ss for a friend, the goal is to run 8-10 pounds with a conservitive tune and chances are the boost will never be turned any higher.
ive been told by a few people that a single walbro will support that power but i really dont want to be on the edge with this build ( the car has 3800 miles on it)
Anyone have any other ideas....twin walbros seem to be overkill
I have to keep stock lines and fuel rails and plan on running alycontrol meth and motoron 60's
if you have had a simular setup with a single walbro let me know
thanks
thanks
i have a single racetronix pump (walbro 255lph) with the hotwire kit and it will be fine to about 500whp.
also if you plan on running the stock motor a 10 psi, i would seriously consider 317 heads and some methanol. and a very very good tuner.
