New Power Steering Pump?
Old 06-02-2009, 11:02 AM
xbcrguy182x's Avatar
Default New Power Steering Pump?
Would a new power steering pump solve my hard steering issue? Steering the car while parking is very very hard. And on the road, it's just takes more effort to steer. Would a worn Power Steering Pump cause stiff steering? Maybe it's not pumping enough fluid.
I flushed the system with new fluid and bled it. It didn't help much. Thanks.
Old 06-03-2009, 07:59 PM
joshp14's Avatar
Could be a pump, gear, or restricted line. Its tough to find a p/s problem without a p/s analyzer that allows you to see the actual pressure that the pump is putting out. Do you get any assist at all or is it just diminished?
Old 06-04-2009, 12:14 PM
I do get assist. I know the pump is working. When I turn from end to end, you can hear it make that hissing sound. Is it suppose to be quiet?
Old 06-04-2009, 03:05 PM
LS6427's Avatar
It should be silent. Your pump is probably worn out, but still works some. As long as you know the system was flushed well and there's no obstructions.
