Slip Yoke Issue
Old 06-02-2009, 01:02 PM
tee-boy's Avatar
Default Slip Yoke Issue
Slip yoke supposed to slide all the way into the transmission output?
I had a driveshaft built according to measurement for my 400 trans. When the rear universal joint is bolted to the pinion flange, the slip yoke could actually slide in another 2 inches into the trans. The builder tells me this is normal. Could someone help me out here.
Old 06-03-2009, 02:23 PM
tee-boy's Avatar
so, what do ya'll know? Is this going to ruin my new transmission?
Old 06-03-2009, 04:24 PM
SS SLP2's Avatar
is the two inch slack with the suspension loaded? if so I think this would be bad on tail shift and on the yoke both
JUST MY .02' Johnny
Old 06-03-2009, 05:30 PM
MIGHTYMOUSE's Avatar
3/4" is a ton on our cars, ive seen people have 1/4" and not bust anything.
thats more for cars with leaf rear ends / bad geometry
i would get a longer shaft sorry
Old 06-03-2009, 06:18 PM
tee-boy's Avatar
yes this is with suspension loaded. rear and front tires on ramps. pinion angle is right at -2 degrees.
Old 06-04-2009, 10:33 AM
ShevrolayZ28's Avatar
That sounds too short, but I guess it also matters how long the splines on the slip yoke are.
Is there a lot of slop if you grab the shaft at the front and wiggle it?
Old 06-04-2009, 08:15 PM
tee-boy's Avatar
slip yoke is 4" total. engagement into trans is 2.75". this leaves 1.25" of "play" on the slip yoke.
not any slop if you wiggle.
Quick Reply: Slip Yoke Issue
