Engine Lugging in 4th Gear at Low RPM
Situation: 98 Auto Trans Am. As soon as car transitions into 4L I get engine lugging. Lugging only occurs at low RPM (about 1500), thus around 41-48 MPH. What makes this odd is that it seems to only occur during or within a day of extremely wet conditions (i.e. heavy rain).
For those knowledgeable, let me know if any of the following are probable causes: bad transmission (chose your words carefully), faulty app sensor, or bad torque convertor. I'm leaning towards app sensor but after careful inspection I don't see anyway that heavy moisture would cause the fault. Torque Converter is a close second but I'd rather not shell out dough just yet for a new one so any thoughts are very much appreciated.
I found a broken gasket that is causing oil to dip on to the o2 sensor wire inputs, is this enough to cause an o2 malfunction?
