car wont start after mt. mount install
Old 06-03-2009, 04:48 PM
1979rs/z28's Avatar
Default car wont start after mt. mount install
just got done putting in protane motor mounts and now the car wont start, fuel pumps coming on, checked all fuse and relays... im stumped ran fine prior to this. what gives?
Old 06-03-2009, 04:56 PM
94'BLKBRD's Avatar
What did you remove/disconnect when you did the install?
Alternator wiring harness?
Old 06-03-2009, 05:01 PM
1979rs/z28's Avatar
the wires look fine from the alt. its all connected and tight.
Old 06-03-2009, 06:42 PM
Z28M6TT's Avatar
is the starter cranking? maby a wire got tugged when you jacked up the motor. also did u take off the starter to get the mount in? maby knocked something loose....
Old 06-03-2009, 07:22 PM
1979rs/z28's Avatar
It was one of the wires going to the cps not making contact all the way thru to the sensor not giving it power... It had me about to pull my hair out but thanks guys!
