truck oil pan good for drag racing?
was curious if the oem lq9 truck pan is good for drag racing or not? i was thinking it would be better since it is higher capacity and rear sumped...
was also curious whether or not it will fit on a stock 4th gen k member... i dont mind cutting and boxing if necessary....
also for people who have run it... how bad is the ground clearance on a stock ride height car?
Here's a link from the conversions section with all the various pan dimensions: https://ls1tech.com/forums/conversio...-oil-pans.html
According to that the truck pan is 1" deeper at the very front and 3 1/4" deeper at the back. I think, looking at that info, that the pan will hang a good 2" past the bottom of the k-member.
