Will a 4L60e from a 98-02 Fbody work in a 94 Camaro?
Old 06-04-2009, 03:55 PM
Holeshotz's Avatar
Default Will a 4L60e from a 98-02 Fbody work in a 94 Camaro?
Old 06-04-2009, 05:15 PM
LS1Tech Sponsor
performabuilt's Avatar
No wrong -electronics, converter, input shaft, pump staton etc .
Adaptation is possible but would be alotta trouble . If you think the 98 up 60e is stronger as a reason for the swap that assumption would be incorrect.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-04-2009, 08:49 PM
Holeshotz's Avatar
Thanks For the quick response.
