Which cam for 6.0L lq9, Cartek Stg IIx heads, Ported LS6 intake?
Old 06-04-2009, 04:57 PM
MBC Racing's Avatar
Default Which cam for 6.0L lq9, Cartek Stg IIx heads, Ported LS6 intake?
Putting a new motor together after the stroker blew up
Which cam for 6.0L lq9, Cartek Stg IIx heads, Ported LS6 intake, Long tubes, 12 bolt with 3.73s, Yank ss3600 or ss4000 stall (still not decided)?
Car is full weitght (3783 with driver). Used to be used for AX and road racing but will now be cruise night and ocassional drag strip car. I plan to drive it to and from the strip and to and from work once in a while so it needs to be streetable. I have not decided on the stall yet, but am leaning towards the ss4000.
I have to dig up my flow numbers on the heads since they were flowed here in chicago when they got fixed and worked a little more for my 383 that they came off. Heads made good power with the cam listed below, but was set up for road racing and the M6, not drag. Put over 400 rwtq from 3200-6000 rpm. which is what i needed to come out of corners vs peaky high rpm power.
I have searched and looked, but there are so many combos out there..... Would really like to see someone with a similar combo as mine.
Any info is appreciated.
Thanks
Quick Reply: Which cam for 6.0L lq9, Cartek Stg IIx heads, Ported LS6 intake?
