ls6 heads cam install need help on preload!!
well i got a stock ls6 01 motor stock right now. im going to install prc springs with a 660lift rate. using a torquer v2 cam 595. 598. lift 114. milled heads by .020 or give it a new surface. Using stock new ls6 valves. using stocker lifters and stock head gaskets. Porting the heads too. im just confused on what size of push rods i would be needing. If someone can please help me out i would appreciate it. Using brand new ls7 lifters too. it says they have .80 preload on the lifters.
can someone help understand how to determine the rod length please thanks
