Meth Kit
Old 06-07-2009, 10:26 PM
acevhartz1's Avatar
Default Meth Kit
I am thinking of putting a gallon meth kit on my 04 turbo charged gto, but I am second guessing myself because I wonder if a stock fuel system will be able to handle it....
Old 06-08-2009, 05:11 AM
EPP
EPP's Avatar
The methanol kit can actually help out if the fuel system is marginal. Bob
Old 06-08-2009, 08:25 AM
Dumb Ass Vette Moderator
ls1290's Avatar
True, but if the tune is relying on the methanol, then make sure the methanol tank is always full.
Old 06-08-2009, 10:15 AM
MaxxMitchell's Avatar
Does the current fuel system support what your current power level is? Meth injection will help as Bob said as you are adding more fuel, but by a different method. If you have not gotten the turbo set up together, then I would decide on how much power you are looking for, and build your fuel system around that first. Add meth injection into the loop afterwards, knowing that if you wanted you could support all your power on just racegas with no meth in the future if you wanted.
Old 06-08-2009, 05:13 PM
acevhartz1's Avatar
I have an sts system installed, and just a bone stock fuel system, with 45 lb injectors
