Gears & Axles - 3.73s or 4.10s stronger?
View Full Version : 3.73s or 4.10s stronger?
k0261886
06-10-2009, 12:55 PM
Which are stronger in the stock 10 bolt? The 3.73 gears are 11:41, and the 4.10s are 10:41, but I always heard that the 3.73s are the stronger gears. Is that true?
redbird555
06-10-2009, 01:05 PM
In theory yes because you have more teeth binding together. It seems to hold true for most people they have 2.73's and all is good then go to a 4.10 set and blow the 10 bolt rear. In all honesty I think its all how you drive :drive:
STEEPSS
06-14-2009, 11:30 AM
3.73's are going to be the stronger of the two. However, if you're putting them in a 10 bolt, SAVE YOUR MONEY. Just wait until you can afford a 12 bolt or 9". Expensive, yes, worth it, definitely.
