Stuck in gear now no reverse? WTF
so i went to the gas station last night and parked my car up front, put it in gear after i shut it off and went inside. i came out and put it into reverse just fine started to back up, clutched it to shift into first only the shifter wouldnt release out of reverse. i pulled as hard as i could to get it to move but it wouldnt. so i shut the car off pushed it back up to the store front and tried clutching it again to get it out. i pulled as hard as i could, wiggled it, kept letting the clutch in and out but to no avail. finally it let loose but it acted like it was sticky ( have a B&M ripper on it. wouldnt re-center itself) so finally i kept starting the car and pumping the clutch while i was wiggling the shifter and it finally "let loose" and started re-centering and acting smooth. 1-6th is fine but now i cant even get into reverse. It will go all the way to the right and gate up some but it wont let it engage. The car has a mcleod ST on it and the tranny has already been rebuilt with upgrades. I have no flippin idea where to even start at. Any and all suggestions will be gone through. Thanks guys.
