need a help guys
need a help guys
Hi guys..
i have a problem with my fuel pump
the fuel pressure comes down on high rpm around 5000 rpm and above
my engine is 408 with TVS 2300 11 psi
what u recommend me to do
Suggest you post up the details of the system.
IE:
Pump is stock, Walbro, etc?
Returnless plumbed?
Adj regulator? if so, is it boost referenced?
Stock pump location?
Electrical system to pump is?
Base psi, and the psi @ 5000?
Data logs available?
How is the engine tuned?
IE:
Returnless plumbed?
IE:
Returnless plumbed?
IE:
Returnless plumbed?
Returnless Plump? Yes
Adj Regulator? No (60psi) Is it Boost referenced? No
Stock Pump Location? In-Tank
Electrical System to pump is? Stock (Bolt-on)
Base psi? 11psi psi @ 5000? 11psi
Data Logs available? No, because i tried cruising in it and accelrating the fuel pressure drops down instead of keeping stable or going above.
How is engine tuned? Engine tuned on Dyno and is perfectly tuned upto 4500rpm because after that the fuel pressure drops and down and the engine doesn't get enough fuel.
The main problem that i am facing is that when i cruise in my truck the fuel pressure is not constant, it keeps dropping, i have checked all the electrical wirings and lines and everything seems to be well fitted. But when i accelerate the fuel pressure drops down and the car starts to jump like it doesn't have fuel, (like it loses rpm and goes up again)...
I am trying to tune it but i can't go above 5000rpm where the fuel pressure falls down straight away...
Will the fuel catch tank solve the problem, and how does it work if it will?
Thanks
I really appreciate any help, Thanks again to everyone in advance..
A.R.D
LS1TECH Sponsor
The proper fuel system setup will solve your problem. You have a big pump, but are not utilizing it correctly for your application.
Please contact me for a solution to your problem. 724-322-8595.
9:00am-11:00pm eastern time, weekdays & weekends.
I've done many systems well into the 1000+rwhp range, so I can suit your needs.
