U/D Powerbond removal help!
i have a powerbond UD pulley, im trying to take it off with a puller but theres nowhere to seat the puller on?? can anyone with powerbond pullies please help?? thanks!
I believe the Powerbond pulley has holes through the spokes where you use a steering wheel puller type puller. You put the bolts through the puller, then thread them into the pulley. You can get one from Autozone. They call it a harmonic balancer puller. It's not a 3 jaw puller.
LS1Tech Sponsor
I think he is asking what to put on the crank to push against. People use all sorts of shims/spacers including sockets, solid washers, orig crank bolts, etc. I would recommend either of the first couple, but maybe NOT the orig crank bolt. It might cause some problems later on....
