10.5 EZ Street build.
Old 06-14-2009, 11:57 PM
StreetSilverado's Avatar
Default 10.5 EZ Street build.
Here's a new build project I'm starting for my buddy who is leaving for Kuwait in about two weeks. So everyone here's the specs.
EZ Street 10.5 Class
Single Power Adder Allowed (Multiple Stages of Nitrous Allowed)
Cars must have stock appearing Head Lights and working Tail Lights
NO 4 Links!
NO WHEELIE BARS
Stock firewall must remain in Stock Location
All cars must run either Gasoline or Alcohol
Decals or Lettering on paint to EXTREME MINIMUM
Any Induction/Injection Allowed
No Sheet metal Intake Manifolds
Mufflers required for all vehicles except vehicles with Turbo Charger. Exhaust must be directed toward rear of vehicle, no frontal or side exit in front of front wheels
Any Drag Radial Tires
Mini Tubs Allowed
Stock Interior is Mandatory Back Seat may be removed for Roll Cage clearance
Glass windshield and driver side and passenger side windows Required
Winning drivers must weigh after each round
Mandatory engine Blanket
If EZ Street or Super Street have 5 or less cars the two classes will be merged and will still follow what ever rules for the class you originally run.
Weights
Small Blocks with Nitrous - 2800 lbs
Big Blocks with Nitrous - 3000 lbs
Small Blocks with Superchargers or Turbos - 3100 lbs
Any Car Equipped with a Clutchless Transmission will carry a 100 lbs Extra
Four link cars - 3200 lbs
Big Block with Turbos or Supercharges - 3200 lbs
Small Blocks with Four Links and Nitrous - 2900 lbs
So here's us starting to tear it down. Plans are a 410CI with a 106mm Single Turbo.
And here's how we work...
Old 06-15-2009, 06:50 AM
nastychevelle's Avatar
6 bolt heads would be a good idea then a vic jr with a 4150 style TB and a carb hat drilled for 16 80# injectors and run it on alcohol
Old 06-15-2009, 07:29 AM
PREDATOR-Z's Avatar
That is similar to the class I run.
I run Super Street, nitrous 2 stage dry/wet
06/07 UAE champion
Old 06-15-2009, 08:07 PM
Day two
