Speed Inc. LS2 GTO/APS results
Old 06-16-2009, 12:51 PM
LS1 SPEED's Avatar
Default Speed Inc. LS2 GTO/APS results
We seen some great results from an Ls2 GTO with an APS kit we finished tuning today. We helped this customer with the build, but he did all the installs himself.
6 speed w/ Spec 3+ clutch
stock short
stock unported heads w/ Patriot Golds
stock unported intake and throttle body
our TU1 225/225 cam
crush bent 3" exhaust into a set of Magnaflow mufflers
our first twin intank 255 pump setup along w/ stock rails and an Aeromotive Reg.
2 bar w/ HP Tuners
7.5 psi / 93 octane
616 rwhp
565 rwtq
13.3 psi / 100 octane
773 rwhp
702 rwtq
16 degress @ peak TQ
18 degrees @ peak HP
Old 06-16-2009, 01:38 PM
Tiago's Avatar
those are great numbers for stock motor.
PS I tried to PM you but it didn't work so I emailed you through the board.
Old 06-16-2009, 02:04 PM
LS1 SPEED's Avatar
thanks
emailed replied
Old 06-16-2009, 02:17 PM
extremetoy's Avatar
whats the compression ratio with the stock shortblock
Old 06-16-2009, 02:21 PM
allthrotle's Avatar
those are great numbers for a stock ls2 with a cam.
Old 06-16-2009, 02:45 PM
LS1Tech Sponsor
hellbents10's Avatar
Great numbers!
Old 06-16-2009, 03:35 PM
98turbls1's Avatar
Wow! This makes me want to get my APS kit on my goat.
Old 06-16-2009, 03:40 PM
LS1 SPEED's Avatar
big HP so simple
have to love the LS motors
Old 06-16-2009, 03:52 PM
MY99TAWS6's Avatar
Any alc or meth injection used?
Old 06-16-2009, 04:52 PM
Tom@SpeedInc's Avatar
no sir, however pump 100 octane was used for anything above WG spring pressure.
Old 06-16-2009, 09:04 PM
9sectruck's Avatar
can you guys tell me where I can find the aps kit for my 06 gto?
Old 06-16-2009, 09:57 PM
LS1Silverado05's Avatar
Pretty damn impressive!
Old 06-17-2009, 12:50 AM
Italiankid77's Avatar
Very impressive man I love the LS1.
Old 06-17-2009, 01:05 AM
MY99TAWS6's Avatar
Oh was this m6 or auto car? If m6 what clutch? And how do you get a car with this much power to hook on the dyno?. I have not gone to dyno mine yet but hearing stories about can't get them to hook to test them.
Old 06-17-2009, 01:15 AM
Its an M6
largest reasons why it hooked on the dyno
1. Nitto 555R tires
2. its stock motor/ci the torque with the additional of a small cam, vs. a 402 with APS, peak torque is same however under the curve the 402 hits peak torque at 3500rpm where as this build hits peak torque much later. Linear delivery of torque.
My car had issues with tire spin, this car did not.
And camshaft, 225/225 113 LSA.... something David Vizard wouldn't spec in a million years for this application
Its an LS2 and honestly I think its the highest dynoing stock block LS2 (?)
Old 06-17-2009, 01:19 AM
MY99TAWS6's Avatar
What clutch? So I can expect my built 408 to be harder to dyno? Should I use et street radials to better hook it up? It is easier to hook on a mustang or dynojet? Would think mustang as it puts load on there although newer dynojets can do both inertia and load I think ?
Old 06-17-2009, 01:31 AM
This car runs a Spec 3+ clutch
yes ET street radials best choice
far as the dyno is concerned, if their was no load on a dyno jet how would the tires spin on the dyno? Realistically we've logged runs on the dyno jet then at the track and logs result almost dead on.
Old 06-17-2009, 04:50 AM
Mr Monaro's Avatar
Good advice as usual and nice numbers go Frase and Speed inc.
Old 06-17-2009, 07:47 AM
52172's Avatar
Nice jobs guys!!
Old 06-17-2009, 05:42 PM
98turbls1's Avatar
You got any pics of this? I'm interested in the fuel system (figuring out how to do mine). Are you guys going to do a twin pump kit for the gto's or is this a one of thing?
Quick Reply: Speed Inc. LS2 GTO/APS results
