what heads are better
Old 06-16-2009, 08:16 PM
mikemunoz's Avatar
Default what heads are better
i dont know what heads are better pleace put them in order
1.)853
2.)807
3.)317
4.)243
5.)241
i dont know what other heads are there feel free to add them in thanks for the help
Old 06-16-2009, 08:56 PM
SOMbitch's Avatar
243 hands down on a N/A motor.
317 are big chamber 243's and best for F/I use as they lower compression.
241's are marginally better than the rest because the casting process is slightly better but not really enough to make up for car to car differences.
Flip a coin between the rest.....
Old 06-17-2009, 07:34 AM
Mac 2002 SS's Avatar
243 Livernois Stg II LS6 Heads .
Old 06-17-2009, 08:22 AM
bigboykilroy's Avatar
243's Stage 2 by TEA !!
Old 06-17-2009, 09:14 AM
dferg99's Avatar
What about if you port them does that even the playing fields. The reason I'm asking I have ported 853's now on a 370 iron block that flow 305@ 600 lift. Will the unported 243 flow better than ported 853?
Old 06-17-2009, 01:46 PM
IDK ,but you can call any of the top doggs ( LM,TEA,AFR, etc.) and they will be glad to answer your question. I know Livernois Motorsports (LM)and Texas Speed will be glad to help you out for sure. Hope this helps
Old 06-17-2009, 02:39 PM
BriancWS6's Avatar
What you have should be better than UN-ported 243s if the port work was done correctly. Port the 243s and then they will be better.
