I have almost all of my turbo stuff .......
This kills me. I could start the assymbly of this project where it not for the sand in my block. Stuff for my build that I have.
Intercooler 31" X 12" X4"
cold pipes 3" Aluminium with Vband clamps
303 stainless steel hot pipes keeping the AC That means I will be putting the AC back in.
90mm Garrett Ball bearing turbo
turbonetics NewGen waste gate
Guages are PLX multiguages 3 for the A pillar and a 60mm for the center vent on my dash.
PLX OBD II device
PLX wideband
PLX boost/vacume module
Profec IIb Eboost controler
72lb Seimens injectors
105mm John Stewart Ls Spyder sheet metal intake
105mm TB
Custom fuel rails
ported 317 heads
Patriot dual spring kit
1 3/4 Stainless steel turbo headers
I already have dual fuel pumps with factory lines.
I need a BOV. Air filter.....???? And what else would you guys recomend? The block it was going on was big. Insurance is covering the vandalism so I'll have some extra cash to spend plus another engine to build. What would be the best 4xx cube engine? This car is a street car and will be driven a lot. Almost daily even.
PLX OBD II device
PLX wideband
105mm TB
Custom fuel rails
ported 317 heads
