AC not as cool as can be. Recently serviced...
I had a leak in the schrader valve, so I replaced it. Vacuumed the system and added some high mileage r134 to the proper pressure. The air blows okay somewhat cold, but I know it should be better.
Should I try replacing some components?
Or try the synthetic 134's?
Anyone have some insight.
What the hell are you comparing? You are being faaaaar to general, zero detail. Let me help:
What is the outside temp and humidity at time of test?
vs.
What is the output temp at the center vent? Take this after 5-10 minutes of cool down time.
What is the delta between the two? This will tell you the relative performance of the system.
vs.
