delayed 2-3 shift..billet servos installed
ok i have a 94 4l60e that i just rebuilt red alto clutches and 3-4 .025 clearance and have billet servos and all pinless pistons installed also the 3-4 spring loaded check valve in the drum.when it shifts 2-3 its a good second before the shift completes . how can i get a quicker shift.I am worried i will fry the clutches again if it shifts like that wot.1-2 feels ok and it seems like 3-4 was a little quicker than2-3 but not much.I will be doing a pressure test today to see where its at..by the way i should just check it in reverse right?
The 2nd to 3rd just feels like your normal delayed shift.You can just feel the hydraulics doing there thing but just feels sloppy.Ive had a problem before the rebuild with 2-3rd felling like this. I was hoping setting the clutches tighter this time around would fix it , but apparently that wasnt the case.oh and btw..still having that dam taking off in 2nd or third.This thing is being a pain all the way around.
