Notices
WTB: Rear axle for 3 channel/non TCS 10 bolt
Old 06-22-2009, 10:27 PM
SparkyJJO's Avatar
Default WTB: Rear axle for 3 channel/non TCS 10 bolt
I'm looking for a rear axle for a 3 channel ABS, non TCS 10 bolt. Must be in very good condition with no wear on the bearing surface, no damaged splines, etc.
Mine is worn from a bad bearing so I was going to use the Timken offset bearing, but I've read too much about the seal not sealing so I think I've decided to go with OEM style bearing and seal. Thus I need a new axle.
PM me with what you've got, with a price shipped to ZIP code 44813, with pictures of the axle too please (specifically bearing surface and splines). Alternatively, I live in central Ohio (near Mansfield) so if you are nearby I'll pick it up or meet you someplace.
Thanks!
