rx7 v8 running problem?
Old 06-23-2009, 07:46 AM
mattorx7's Avatar
Default rx7 v8 running problem?
hi i have an ls1 v8 engine in my rx7 and the car is near completion but i have a problem the car starts up and runs for a few seconds then cuts of and stops i thought maybe the ecu was looked but i have tried another which has been unlocked and it was the same any ideas what it could be?
Old 06-23-2009, 08:36 AM
Cold Zero's Avatar
Dynomo Charge ?
Old 06-23-2009, 10:04 AM
pdsq98gt's Avatar
VATS. Did you have someone flash the PCM to remove VATS?
Old 06-23-2009, 10:59 AM
Aaron1017's Avatar
Most likely VATS.
Check out www.v8rx7forum.com if you havent.
Old 06-24-2009, 06:38 AM
mattorx7's Avatar
thanks for the replies the alternator is not on it yet didnt think that would effect it? i had a feeling the vats may be causing it i will have to get someone to check it through the obd2 port i guess
Old 06-25-2009, 03:15 PM
Restricted User
speeddemon651's Avatar
sounds like Vats, what year PCM is it ?
