Biggest CID to go with MTI Stg 2 heads?
I wanted to go all bore 382, but I've already spent so much on my heads that I'm really not wanting to spend a crapload more to get the heads to match up w/the bore...what would be a good bore size for a stage 2 head?
Not an all bore 382, but possibly a bore/stroke 382 or even a 370? You can run a 370 cid w/the aluminum block correct or does it have to be the iron block?
