What are you using for a main power relay
Old 06-25-2009, 12:43 PM
jkwalkercchs's Avatar
Default What are you using for a main power relay
ok so im bout to wire up a ls1 4l60e combo in a 69 camaro
most of the wiring jobs i have done i used kill switches for the main power since they were rockcrawlers
but no push button start or kill switch o this car it needs to look pretty lol
i saw kb racing used a 30/40a relay for all the ignition on is that enough or do i need bigger?
Old 06-25-2009, 02:38 PM
TomM's Avatar
A 40 amp should be good for ignition. Fuel pump relay is seperate, so you should be good. 40 is plenty...
T,
Old 06-25-2009, 03:24 PM
Restricted User
speeddemon651's Avatar
should have no problem with that even if your running a high torque starter
