Flycutting with AFR 205's
Old 06-28-2009, 01:29 AM
TransAmcoupe98's Avatar
Default Flycutting with AFR 205's
I got a Polluter cam going in my LS6 motor. I'm alos getting a pair of AFR 205's with 65cc. Do you guys think I'm going to have to flycut with this cam?
Old 06-28-2009, 07:28 AM
Red99TA's Avatar
I'm thinking no since the AFRs are only milled 1 cc or not milled at all (thought they were 66cc stock). Anyways, best way to know for sure is to get some clay and check PTV clearance yourself - its not that hard especially considering the consequences if you don't and your pistons kiss the valves.
Old 06-28-2009, 01:06 PM
JPH
JPH's Avatar
It should clear, but I sayd you will be in the range of .039-.051 ptv on the intake side, and .090+ on the exhaust.
