5.3 aluminum L33 IN THE GARAGE...WHAT TO DO?
So I have a 70,000 mile complete aluminum l33 5.3 in the garage. Heres my plan. Its going in a 91 fox coupe, Ive been a ford guy forever, however i have owned an 01 ss camaro, a 69 z28, and a 99 silverado in the past. Ive had easily 20 turdstangs though.
anyway, im considering flipped manifolds and mpt70 turbo, yadda yadda.
I started thinking though my 91 coupe doesnt way ****. This motor makes 310hp stock and already has ls6 heads and is a light motor.
What are typical numbers for this motor with mods? Its already 9.9:1 comp and has decent flowing 799 heads.
I dont want to pull the heads.
What would you guys do? All mods considered but heads stay on!
Intakes cams exhaust is all good!
Just lookin for a low 10 second ride the cheapest way possible.
Also labor is of no concern i do all my own work, so turbo or not I will do everything.
Enlighten me bowtie boys what do u think this baby z06 motor can do!
Oh and proven combos are always nice to see!
zo6 cam and valve springs
ls6 intake with ported TB
60# injectors
do a search on the ford fairmont that parish8 built it went something like 9.49 with a 5.3 with a zo6 cam and a t70
edit here are some threads on the fairmont
https://ls1tech.com/forums/multimedi...ect-pinks.html
https://ls1tech.com/forums/multimedi...track-vid.html
https://ls1tech.com/forums/hot-rod-p...light=fairmont
https://ls1tech.com/forums/multimedi...light=fairmont
https://ls1tech.com/forums/forced-in...-cam-swap.html
60# injectors
LS1Tech Sponsor
We did a cool L33 build with just a LS6 cam and good springs. Also a stock truck intake or ls1 intake would be just fine for low 10 second passes, save some more money that way.
Check the thread.
https://ls1tech.com/forums/forced-in...id-inside.html
Check the thread.
Check the thread.
Check the thread.
I think im just gonna turbo the fcker! I dont own anything not boosted now so why not. Im interested in using the combo of megasquirt to tune fuel and msd 6010 to control spark, paired with a wideband & i should be good to go as far as making the engine run and be tuned on the cheap! I like the looks of hptuners but for less money i can make this thing run & tune it without hunting down a factory harness to modify. Anybody gone this route? Seems good in theory, real life i dont know?
