Lack of Power..
Lack of Power..
hey guys, I bought a 99 TA over the winter and when I first bought the car it seemed to have loads of power and would very easily break the tires loose from 20-25 mph. Now 6 months later the car can not do it from a roll, but seems as if the car might have a slight hesitation. The car does need plug wires but I have already replaced all the plugs less then 1k miles ago but the car does have a misfire when under load in a high gear. The car has been properly maintained with all fluids being changed since I have gotten it. And the engine does not make any odd noises and has 133k miles on it, its a manual trans if that matters. Let me know what you guys think.
Thanks,
Alex
Thanks,
Alex
Save the manuals!
There is a great debate about the oil on K&N filters. GM says that they shed oil on to the MAF (which it can't burn off) and end up fouling the sensor. K&N says that GM has faulty sensors that leak silicone on to the wires.
In my case, I definitely had an oil shedding problem. I cleaned my MAF, went back to paper, and life has been great ever since. A lot of people will over-oil their K&N filters, leading more quickly to the issue.
