Need help Please Read!
I am doing a transmission swap for a friend that has a 95 Chevy 1500 2wd....The 4l60e that he picked up for the swap is out of a 97 tahoe....It came with a different shift arm and shift bracket so i changed those out and put the 95 Stuff into the 97 transmission....after completeing the job the drive shaft is now just a tad bit to long and wont fit...He was told that the transmission would work...So what have i done wrong?
LS1Tech Sponsor
The actual lengths of the trans should be the same I have however seen a couple of the output shafts that were not splined far enough and this will cause the shaft to not go into the trans far enough in a few application . How far will the ypoke slide into the trans?
__________________
I went and messured and it will only slide in 3.5 inchs...The other trans will take the whole yoke...Im prolly gonna end up cutting the yoke a tad and make it work...But i was just making sure that i did have the right transmission and that mainly it was gonna work
