General Maintenance & Repairs - a/c blowing warm after cam swap
View Full Version : a/c blowing warm after cam swap
lilred1995vette
06-29-2009, 09:01 PM
The compressor still kicks in. But no cold air, just warm air same as vent. Heater/vent still works to. I will check the pressure on system tomarrow.
LS6427
06-29-2009, 09:12 PM
Yeah, you have to start with the easy stuff.
Choppers
06-29-2009, 11:53 PM
let us know the psi reading and we'll go from there. but if the compressor kicks on then there is freon in(usually). did you lose the freon at all or open the system?
thechef
06-30-2009, 12:03 PM
sounds like you forgot to put the freon back in
lilred1995vette
06-30-2009, 07:17 PM
system lines have never been removed and still has factory charge. Just checked with my gauges and high pressure gauge would not work. So i am just going by the low gauge and it reads 30psi with a/c on and 90psi with a/c off.
lilred1995vette
06-30-2009, 09:30 PM
Anyone have the factory specs as far as ls1 camaro a/c psi? on high and low sides?
