Fuel Rail Cap
Fuel Rail Cap
Does anyone know where I can find a -4AN cap for the end of the fuel rail? I am going FI which means I'll be running much higher fuel pressure and I don't trust using the stock plastic cap. Anyone know where I can find a good metal one?
I hooked up a fuel pressure gauge with an adapter that has an extra male port that doesn't accomodate the shrader valve so the cap will be exposed to high fuel pressure. That's why I'm looking for a metal one.
Thanks!
- Sean
Thanks!
- Sean
Never mind, I found some at Summit. Previous searches came up empty. The search functions at some of these vendors are not vauge enough. I finally found them searching by the exact words "Cap Fittings", not -4AN, cap, fuel rail cap, etc.
