A4 z28 making a clunking sound!!
Old 06-30-2009, 01:55 AM
camaro981289's Avatar
Default A4 z28 making a clunking sound!!
I have a 2000 z28 a4 and when i put the car in either R(Reverse) or D(Drive) it makes a clunk sound. Also sometimes when it shifts from 1st to second i feel a little pull and i hear that same clunk sound. Could it be bad u-joints or rear end? Also when i turn u can hear it make some wierd noise...fluid is good...Any help would be appreciated guys thanks.
Old 06-30-2009, 07:04 AM
Mac 2002 SS's Avatar
your tranny mount could be worn out. check to see if there are any cracks or even piece missing from it. when they go bad , your transmission is moving around and thats a " not good thing "-
Old 06-30-2009, 07:18 AM
redbird555's Avatar
might also be your torque arm bushing going out. I had both go bad and when the tranny mount went it sounded like the tranny was gonna drop outta the car whereas the torque mount wasnt as noticeable.
Old 06-30-2009, 08:28 AM
NonGoggleGuy's Avatar
I'd say bad tranny mounts, but I wouldn't completely rule out the u-joints. You gotta get under the car anyways, so check the u-joints first, then yank back-and-forth on the tranny to check the mounts.
Old 06-30-2009, 03:36 PM
Ill check the tranny mounts a torque arm bushings as well as the u-joints since im off today...thnx
