having problems with 96 vortec 5.7
engine starts but misfires try to adjust timing but the light stays in the same place about 5 to 10 degrees advanced its getting fuel and spark. ive checked for compression allready do you think maybe the cam sensor is bad im almost out of ideas any insight would be appreciated
you need to get a tech 2 to set the timing. it just basicly sets the phase of the crank sensor to the distributor. it (cmp retard) needs to be 0. then they will be together. and it should run smooth. from there the computer sets the "timing". i probably said it all wrong. but ive done a few intake gaskets on them and thats how they taught me at the dealer.
fwiw, mercury marine uses a similar setup on their newer style marine engines, and i have seen them to where if the dist. if off like 1/8" it will make the engine miss and run like crap when you rev it up. easy way to fix it is just rotate the dist slightly both ways to see if the miss goes away. i'm sure it is much easier to do with the tech 2 handset.
