98' Valve guide seal part #
Old 11-13-2003, 02:17 PM
BADDLS1SS's Avatar
Default 98' Valve guide seal part #
Anyone know the part# off hand for 98' valve guide seals??? and can they be had through GM parts direct???
Thanks in advance !!
Tom
Old 11-13-2003, 02:55 PM
2xLS1's Avatar
97-01 Intake - 12533586
97-01 Exhaust - 12457652
Unless you are using a double spring that needs the clearance, the 02 and up seals are easier to install. They do not require setting a specific height for the seal and incorporate the spring seat (.010 thicker) with the seal in one piece. Just be sure and remove the old spring seat before installing them.
02 and up Intake - 12482063
02 and up Exhaust - 12482062
Old 11-13-2003, 03:10 PM
BADDLS1SS's Avatar
Yes im going to be using Rev 1116 dual springs so i would need the older vavle guide seals then im assuming.
Old 11-13-2003, 04:17 PM
jrp
SN95 Director
jrp's Avatar
just buy the valvestem seal pack from TR for 16 bucks. thats what i did for my rev duals on my 98.
