has anyone ever done this ?????
Old 07-02-2009, 04:02 PM
bloo4.6's Avatar
Default has anyone ever done this ?????
i got a 02 camaro ss and its come that time that im going to get some gears but has anyone ever done 4.56's in a 6 spd ?
Old 07-02-2009, 06:07 PM
01ssreda4's Avatar
i know someone who has 4.30s in a 9 inch. he drives it on the street all the time. He runs a taller tire at the track though thats why he got them i guess.
Old 07-02-2009, 07:26 PM
Duffster's Avatar
I'm currently running 4.30s. Nothing against them , but I recommend 4.11s prior to the 4.56s. It'll keep your engine rpm down on the highway and still give great reactions at the track. . .
Old 07-02-2009, 08:21 PM
FirstYrLS1Z's Avatar
LS1Tech 20 Year Member
I'm running 4.56s' in an A4 auto for 2 years now,with 3 trips from Ohio to Florida.M6 shouldn't be much different.
Old 07-02-2009, 08:38 PM
drummydummy's Avatar
That's flippin' crazy man!!
What are your RPM's at like 60mph? 4,000?!?!
Old 07-21-2009, 09:35 AM
a true 2500 rpm at true 60 mph.
Old 07-21-2009, 04:23 PM
01ssreda4's Avatar
wow, dude we run 80+ on the hwys over here. I couldnt imagine that with 4.56 gears.
Old 07-21-2009, 07:03 PM
thebassbass's Avatar
i run 4.56's in my m6 gto but i also run a 28" tire in the back. at 60 in 6th i am doing around 1800rpm and @80 i am around 2300. just add about 3 to 400rpms to that and that is what it would be with a 26" tire
Old 07-21-2009, 07:56 PM
RsSean's Avatar
Damn that sucks
That would be more like it
Old 07-21-2009, 09:39 PM
Demon 383's Avatar
Man that would suck for me, considering i'm rarely under 80 on the highway. May I ask what was your reason for going 4.56's in an A4?
Old 07-21-2009, 11:40 PM
Duffster's Avatar
that sucks. . . . I'm 1950 RPM at 70MPH
Old 07-26-2009, 05:54 PM
Why 4.56s' in my A4,I'm old school from when gears ruled the streets.
It's a daily driver except when it snows here in ohio.
Torque,Torque,Torque! Torque accelerates,horsepower maintains.
I'm 'old school' from the 60s' when torque and gears ruled the streets.I've worked on rearends back then so they are not something to avoid working on.Back in the late 60s',you could get factory 4.56s/4.88s in your car order in camaros,novas,and chevelles.They were great 'light to light' streetfighters.So why not build a rearend for optimal 'light to light' streetfighting.I have 3 extra rearends(take-outs from f-bod),many gearsets(from swap meets and Summit 'discount returned items,2.41,2.73.3.23,3.42,3.73,4.10,4.56),various carriers(auburns,torsens,and eatons).
When I decided to take out the OEM 3.23 rearend(passenger side carrier bearing was growling),I figured why not build a rear with the $25 used richmond 4.56 gearset I picked up at a swap meet.That rearend was put in in sept. of 07 and I haven't regretted it since.1st and 2nd(with Nitto 315s on the street)are incredible.I've taken 3 trips to florida from cleveland,ohio with the 4.56s' and the computor has handled the mpg better than originally anticipated.24.5 mpg with the 3.23s,now 21.5 mpg with the 4.56s.No complaint here.Freeway rpm would be considered high,but I don't.It's designed to work in a range.Coming back from florida a few weeks ago,we hooked in with a fast traveling group on I-95/I-26/I-77 in South Carolina that put us in cruise control at 4000 rpm for a couple hours.The engine now has an incredible mechanical advantage over the car and it operates at a condition of not being under a load.
